got a pyrometer installed? am interested how much the turbo affects the 3rd-4th tranny hole
I do. I have a pyro and a rail pressure gauge since I turned the pump up. I keep it under 200 psi and I was able to get it above 1000 degrees before I installed the turbo. I don't like that.
With the turbo it does pull better from 16-1700 after I shift into 4th and I'm not able to get it above 900 degrees pre-turbo no matter what I do.
I pulled a decent grade in 4th.
Rpms: 2100
Pyro: 900
Rail pressure: 160
Boost: 8 psi.
That was what I was shooting for so I'm happy.
That was me controlling it with the pedal since it's capable of 230+ psi and 2400+ rpm. I have to turn things back down a little so it's not so "busy" to keep an eye on all the gauges.
It could make a lot of boost but I want to start out with 8 and maybe go as high as 10 psi, tops. I want this motor to last 200-300,000.
The turbo was a good step. I'll post pictures. It was a very quick and dirty (one day), very Mad Max and pretty ridiculous install, but I like it.
