Where can I find Fuel Cap & Door?
Warthog
232
OKC, OK
Used is the only option that I know of. Hawkman, HillbillieWizard or cucvrus may have them
Drock
12
Eatonton GA
I'm collecting the parts to add a second fuel tank to my M1028. And I also need a (complete) fuel door including the whole opening to weld into the body. If anybody has one please PM me. Thanks D
I put my fuel opening on by cutting a hole and then putting the "new" door over it. By rounding the new door panels edges and using large self tapping bolts, it looks sharp. So that you know, I tried a short bed tank first, no go. I used drivers side brackets, and had drill three of the four bolt holes for the front one , but it worked well. Window flashing that comes in a roll and has adhesive on one side, then rubber and sometimes foil, makes great padding between the straps and tank.
