Where do you buy parts at for M101A2 ?
a68cudas
Brookfield, Ohio
Where can you buy parts for the M101A2 trailer at? Can parts be bought from local auto stores or trailer stores? How much do brake drums and shoes run? Does anyone know the bolt size needed to pin the brakes? Thanks
5,169
From another trailer is where most people get their trailer parts from. You might take the parts into a good parts store and find something that might work.
3dAngus
102
Perry, Ga.
Or, if you were more specific, people could help you find the specific part you needed from the different vendors that have them.
For instance, you mention brake drums and shoes. Here are some parts sources listed by SSer NCdeerejeep in another thread.
Here are the Bearing Numbers.
LARGE BEARING/RACE
Inner Bearing 25580
Inner Race 25520
SMALL BEARING/RACE
Outer Bearing 2585
Outer Race 2520
GREASE SEAL
10-36 (double Lip)
The bearing and race numbers are for Timken. They are more expensive. I used china bearings in mine.
Here is a good source for parts. http://www.etrailer.com/
Here are the Bearing and Races:
http://www.etrailer.com/p-25580.html
http://www.etrailer.com/p-25520.html
http://www.etrailer.com/p-2585.html
http://www.etrailer.com/p-2520.html
Seals:
http://www.etrailer.com/p-RG06-070.html
Brake assembly MINUS the parking brake Lever and Strut:
http://www.etrailer.com/p-23510.html Right side
http://www.etrailer.com/p-23510.html Left side
Brake Shoes:
http://www.etrailer.com/p-BP04-160/12-x-2-Hydraulic-Trailer-Brake-Shoe-and-Lining-One-Wheel.html
Also, to disable the surge brake capability, you just put the pin or bolt in the hole on the surge brakes, and that keeps it from activating.
You also put this same pin in when backing up, so it doesn't activate.
swbradley1
Modertator
1,940
Dayton, OH
Etrailer.com has a few parts as Dell pointed out or find someone scrapping a 101.
