Where is the GP Controller?
ecarl4100
Tennessee
As in literally... Where is it? I'm getting ready to try and diagnose starting problems, and I wanted to visually inspect it before I start running the multimeter. Thanks
firefox
General
1,844
52
Berkeley CA
It's under the dash. It is in a black plastic box which is probably dangling down
from the cable that goes to that big circular connector mounted under the dash.
It is a small circuit board that fits in that case.
Warthog
248
OKC, OK
The box is by the steering column. It is about the size of a cigarette pack. I may have a cover over the end. Most are missing.
There are two other boxes at the center of the dash. They are for the STE/ICE diagnostic system.
FatBuddhaBoo
Jacksonville, Fl
You could start with that, but I'd go for lower hanging fruit like air in the fuel, glow plug relay then glow plugs. Took me a few hours to get mine running and it turned out to ultimately be the glow plugs. (had to upgrade the fuel filter regardless and changed the relay just be certain).
Good luck!
