vinhvinny
- 2
- 8
- atlanta GA
where is the wired #568 connected to on 200amp generator?
I upgraded my V to a 200amp generator, all are set up as in the upgraded kits--however the kits has no mention of the wire #568-- the truck can start as normal but would not charge battery or generate any power.
So I put the old 60amp gen back on, and notice that the wire #568 must be connected to that point as in picture where I have the needle pointed to or it won't charge the battery, won't have any power. bundle that 568 with 5A wire won't work either. (In other words, if cut off switch is turned off engine shuts down.)
So I figure that wire #568 must be connected to some where onto the 200amp gen in order to have the gen work properly.
Does anyone know? I need to know for sure before calling the 200amp gen inoperational.
thank you very much
the link below seems to says that wired 568 to be bundled with the 5A the below
http://g503.com/forums/viewtopic.php?f=63&t=221530
thank you very much
