Where is this leak coming from?
kcobean
Sterling, VA
I noticed a small puddle under my left rear brake caliper. Upon closer inspection I see that the brake line into the caliper is dry, the bottom of the piston is dry and the drops are forming on the plate underneath the parking brake actuator. I can’t tell where the fluid is coming from though. Anyone seen this before?
Dock Rocker
72
Jackson ms
I am not trying to be a smarty pants but what kind of fluid is it? Does it smell like hydraulic/oil or brake fluid?
kcobean
Sterling, VA
SMARTY PANTS!!! LOL
It's 99.9% sure it's brake fluid. It's just a little on the brown side of clear. I'm just not familiar with the construction of the calipe with the ebrake integrated into it. Wondering if maybe the fluid is leaking out the back side of the caliper through the ebrake mechanism.
HETvet
Bedford, texas
Highly unlikely. The mechanical brake TYPICALLY has no interaction with the hydraulic brake system. They operate independently of each other. This is why you must twist the piston in as you compress it in; the twist is to “screw” it back in due to the mechanics of how the integrates parking brake works.
Suprman
693
Stratford/Connecticut
I have found if you leave the transmission in gear while the truck is parked for a period you can get a few drips from the transmission.
Carrera911
31
Cumming, Georgia
Mine leaks a little from the diff output seal. It seeps down and drips from the bottom of the caliper. Hard to tell if that’s where it is on the pics. If it’s diff fluid it will have that cat pi*s smell that diff fluid has. Not sure if dot 5 silicone brake fluid has a smell or not.
simp5782
Feo, Fuerte y Formal
9,355
Mason, TN
Diagnostic work is wonderful if you know how to do it. A leak on a truck and wanting people to tell you where it might be coming from with just a picture is a fishing expedition for anyone who tries to help you.
Diagnostic troubleshoot
# 1. Identify the fluid type.
# 2. Spray off the area and clean it and see if the puddle comes back. This also helps with blowback of fluid and other grime from the road and from the front of the truck.
# 3. Add UV dye to the brake fluid and drive it. Check for leaks with the blacklight. If nothing appears are X time then add it to the differential and see if it lights up in your leak area and so on.
Or the alternative. get your little jack out and take the tire off and break that whole area down so see what may be culprit if any.
Diagnostics will save you a lot of time on just swapping any and every part that's there vs effort of doing the work.
jeffy777
VA
Kelly, I am having a small leak from the diff output seal as Carrera911. My HMMWV named Snake had that too. My buddy Roy I sold it to me said he was not worried about it after check the diff oil level. I plan on repairing it at some time bu I have so many other little tings to do first. I just check the diffs as much as I do change the oil. I have yet to really see the oil go down noticeably.
