Where to get cucv body parts
71blksuper4x4
osage city, ks
There are also many more places to find parts for the m1009 and m1008. There is also a great board with a bunch of knowledge at 67-72chevytrucks.com that has the different eras of trucks/blazers etc. which includes 73-91 chevy trucks and blazers. Don't be afraid to join the board to find parts. Trevor
GM72K10
66
Bucks County, Pa.
What he said.
3dubs
Houston, TX
Do not save money on new body parts. You get what you pay for. If it is cheap then it may not fit without modifications that might be a bigger pain than starting with a flat piece sheet metal! If you want to save money go to a junk yard. Do some research and find what body parts wil interchange what will not. Likw the front quarter panels. The only difference may be the side marker lights. If you are replacing both then it may not matter. you also may get some parts for a Blazer from a pick-up. Talk to a shop, look at the catalogs and compare part numbers. With a plasma cutter and a mig welder you can just use sheet metal. You just need to match the curve of the body. Even a body panel from a junk yard that is damaged but the area you need is good, you can get those for almost nothing. It just depends on how much cutting, welding you are cormftorble with. You may just want to spend the money. But saving money means more work for you. A trip to a few junk yards is not too hard.
JohnFire
Pottsville, PA
I had ordered cab corners from jcwhitney for an M1008 and the left and right were from two different manufacturers. One was from keyparts made it taiwan i think. The other was Tabco made in USA. I hate to say it, the Tabco was lighter metal, a lousy stamp that I had to make fit and had no coating on it. The one from Keyparts was heavier metal fit right in and was coated. It must be because we send all of our good scrapmetal to those countries.
