Where to ground 12 v amplifier and lights
Coug
4,169
Olympia/WA
Running to the negative terminal will always be the best connection, but there is no real reason why you can't run to any of the normal ground locations on the truck, as they all go to the battery negative eventually.
Straight to battery eliminates possible bad connections if you go to the body (these things are notorious for bad body grounds due to corrosion).
