4bogginchevys
- 1
- 0
- rathdrum idaho
research
BTW: I re-rolled the brake lines to fit the housing better and stop inside the spring pad...pointing up. the rubber lines go up and over the springs and a simple bracket will attach to one of the u-bolt studs to secure the line, I didn't like the idea of it flopping around and getting ripped off by a stick or something coming around in the wheel. I'll post a pic when the bracket is on and line is secure. right now it's just zip tied while I make a design.
I looked around at some 3/4 and 1 ton trucks before mounting the calipers, for location. I looked carefully for mounting the calipers and came up with this because the brake lines I used are keyed to the caliper, and I wanted the metal lead of the rubber hose pointing up, not down. I guess I could switch brake lines and flip them for the same result putting the bleeder barely above...instead of barely below level. Admittedly, I was rushing to get it done to use the truck today which didn't happen anyways. The calipers are in front of.....and above the axle centerline, the best copy for placement I could do based on other trucks factory placement. Are your brackets behind and above the axle centerline, this will make the rear of the truck want to lift when you brake, instead of pull down toward the street.....thanks for pointing that out, I may switch it when and if the lines ever need removal for another purpose. Thier all blead out now and it was easy enough to do off the bracket. I would still bleed off the bracket with bleeder strait up after hearing stories of serious problems some are having getting all the air out. Could be related...I have the ruffstuff brackets and did not have any problems with them. My bleeder is also on the top... It looks like you put the calipers on the wrong sides?
