Which Fuel Injection Pump for replacement
SLR
Minnesota
I have a 68 Kaiser M35A2. It wouldn't start a month ago, so I have a friend who is a diesel mechanic come look at it. Turns out that the fuel injection pump is shot. He took it to a guy who does rebuilds, and it is toast so it cannot be rebuilt. I am searching for a new one. The pump that came off is an AmeriBosch. Looking around the internet, I am only finding other brands. What do I need to know so I get the correct pump that will work?
Thank you in advance!!!
cattlerepairman
3,242
NORTH (Canada)
The first choice should probably be an identical pump. You are looking for an AMBAC PSB6A pump, NSN 2910-00-908-6320 for the LD/LDT 465 multifuel. You can also use the pump for the LDS engine.
These are not difficult to find; try a well known auction site, for example. Also call a well-stocked military vehicle surplus dealer of your choice.
You did not indicate why the shop was saying your pump was trashed. Is it the hydraulic head? If so, this is a common failure and replacements are available.
If you are asking whether you can replace the pump designed for this engine with another injection pump suitable to supply an inline-6 at the correct timing and pressure, adapted to the LDT engine, I would suggest that absolutely anything is possible, only limited by the thickness of your wallet.
SLR
Minnesota
From what I was told it was burned up, but I am not sure what that exactly means. The reason I ask about which one to replace it with, is that I found a new one made by United Technologies, where the one I have is an AmeriBosch. I am not sure if you can interchange the pumps that are made by several different makers, but the one I am looking at for a replacement looks to be the same.
Here is a pic of the one I am looking at for a replacement.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
That pump should be fine.
Want to sell me your old pump? Even if they do not work as a whole, there is still good parts on it(probably).
texas30cal
87
Brenham Tx.
I guess my ldt isn't set right or the governor doesn't work, I stayed in it a little too long one day, I heard it and looked down, it was at 3000!!!!
Floridianson
2,500
Interlachen Fl.
Were you going down hill? Believe the LDT was 2600. I up shift every gear at 2450 2500rpm and cruse at 1850 1900 in 5th high.
texas30cal
87
Brenham Tx.
No it was on flat ground, I was watching mirrors and just over revved it, by the time I thought "oh s--t" I looked down and saw 3000. I USUALLY shift about 1800-2000 ........but both my other daily drivers are high revving sbc's and for some reason it just didn't ring the bell fast enough. I hate to try it but it definitely won't stop at 2600.
texas30cal
87
Brenham Tx.
I just drove it to town to go eat, it hit 3000 in 2nd and 3rd no problem, don't worry now that I've proved the point I WONT be doing it anymore!!!
1,174
Guessing either your governor is inop or your tach is wrong.
Floridianson
2,500
Interlachen Fl.
Think 1800 is to low that would put you lower than 1500 on the next gear up. Diesels drive different from gas motors. Don't lug them on the up shift.
