overlordofmars
- 11
- 16
- Bear Creek PA
You forgot the worst nut to remove, the one behind the steering wheel who owns the truck. Its like an addiction once your attached you never can let loose.
I've put several PTOs on with the trans in the truck. It is tight. What's impossible to do is check the gear mesh as shown in the TM with the trans in the truck. I just do it by feel because there's no way to get a dial indicator between the PTO and the truck frame.Deuce PTO gearbox to tranny mounting nuts, it was a whole lot easier with the tranny out of the truck. I could never imagine doing this with the tranny still on the truck.
Ty, You must have some awesome dexterity in your fingers! I could probably do the bottom nuts, but the top ones, well that would be a different story. Not a whole lot of room for a wrench, let alone a dial indicator.I've put several PTOs on with the trans in the truck. It is tight. What's impossible to do is check the gear mesh as shown in the TM with the trans in the truck. I just do it by feel because there's no way to get a dial indicator between the PTO and the truck frame.
, Them there are a real PITA!Front cab mount bolts.
Yea, what's really fun is doing it two or three times trying to get the correct number of gaskets between the PTO and the trans.Ty, You must have some awesome dexterity in your fingers! I could probably do the bottom nuts, but the top ones, well that would be a different story. Not a whole lot of room for a wrench, let alone a dial indicator.
No question about it. Others may be hard to access but this one requires lifting the front of the motor about an inch or so just to make the last couple of turns.Steering box bolt. No big deal after you lift the motor.
Just finished doing this. Had to figure out why the left side wasn't putting out any air (40 years of cigarette/cigar butts and a mouse nest).Replacing the defroster duct isn't any fun either.
