Which NOCO Genius Charger for MEP-803A?
nextalcupfan
508
St. Joseph Missouri
I'm currently using a NOCO Genius GEN5X2.
I hooked the charge cables to the unused side terminals on the Optima Red Tops.
It's plugged in 24/7, so I'm not sure why in question 2 you say you need to unhook the batteries for a dual 12V bank charger.
glcaines
2,812
Hiawassee, Georgia
I have now installed the same NOCO charger on my MEP003A genset with Optima Red Tops. It works great and there is no need to disconnect the battery cables.
dav5
203
Mono, Ontario
I use the dual Noco 12V chargers on my 831A. I was concerned about disconnecting the batteries to charge and was advised by Kurt that if the plug doesn't have the ground prong you don't have to disconnect. If my memory is wrong I'm sure Kurt will correct me.
Louis9113
37
Louisiana
I may have mistakenly understood that I needed a 24V charger for the gen set. Basically and dual bank 12V charger will work?
Light in the Dark
6,775
MA
If you want to go with one of those NOCO 12V dual bank units, they stay wired up all the time. The only thing I was told when I called NOCO is that you just want to unplug the charge pack on them, before running the machine. With this pack running, and the alternator producing voltage... you can get into a battery overcharge scenario.
What I do on the machines that come and go is to install (1) of these on the outside of the machine: https://www.amazon.com/gp/product/B009ANV81S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
From this, you can plug a NOCO or similar into it inside the enclosure. All you have to do is run an extension cord to your genset, to get power to it... and unplug the same extension cord when you are about to turn the machine on. Easy.
loosegravel
Just a retired mechanic who's having fun!
504
893
Enumclaw, Washington
That's a clean install! While working in the bus garage for my employer we have 15 amp battery "maintainers" to plug into the buses while they're in the shop being worked on. We've had a couple of these battery maintainers fail as the result of someone cranking the engine over with one plugged into the bus. I believe the extra current draw on the system while cranking the engines over was too much for the 15 amp battery maintainers. Just another reason to unplug them before running the units.
nextalcupfan
508
St. Joseph Missouri
Actually I've had this exact thing happen with my NOCO on my unit.
Didn't seem to hurt anything though, The NOCO just stopped all charging and maintaining on that battery until the voltage dropped.
Can't remember if I had to unplug it to reset or not.
I also want to mention I leave my plugged in all the time and with the unit running and I've only run into an overvoltage once.
Been thinking about installing a contactor that will disconnect the charger automatically when the unit runs though.
loosegravel
504
893
One thing that I've learned over the years is that alternators should not be used as battery chargers. It's very hard on them. Most of us will jump-start a vehicle or a piece of equipment when the batteries are too low to start the engine and then just rely on the alternator to replenish the batteries. I like this thread because it has a preventative measure to it. I have battery maintainers on just about everything that I own also. I'm not sure if these generators have any "parasitic draw" on the batteries when they're not running. But, many of the vehicles that I've worked on over the years can have a pretty good draw on the house batteries with the vehicle turned off. These maintainers will significantly increase the life of the alternators IMO.
  • Like
Reactions: 98G
nextalcupfan
508
St. Joseph Missouri
I think normally they are pretty good about parasitic power draw. After all everything is on mechanical relays.
My set does have a parasitic draw because I installed a Raspberry Pi 4 in it for auto start capabilities.
Hence my NOCO being plugged in 24/7
Coug
4,796
Olympia/WA
For comparison's sake, in the civilian side of things, most home standby type generators use only a trickle charger, and not an alternator to keep the batteries charged. Difference being a home standby is hooked to grid power all the time to keep the battery charged, where a military unit is not and needs independent charging, and faster charging because you never know the situation.
Using a military gen in a standby type application, I don't see any reason why you couldn't disconnect the output of the alternator and have the NOCO's supply on the switched output power from the gen. Either that or you have it plugged into a non-switched power source so it's either the generator off and NOCO providing charge, or the power is off and gen is running with the alternator producing charge current.
glcaines
2,812
Hiawassee, Georgia
I wouldn't want to disconnect the alternator on my MEP003A because it is trailer mounted and I occasionally and sometimes frequently move the genset temporarily to remote areas of my property for temporary power, sometimes for days at a time. I find it no real inconvenience to simply pull the NOCO plug from the wall receptacle when I fire it up when it is located at my house.
Coug
4,796
Olympia/WA
"days at a time" isn't really enough for the batteries to drain down. Unless you have something in it like the remote start/ auto start unit, then that comment wasn't really aimed at you.
My 802A sits for months at a time and has no issues starting up again.
One nice thing about having the charger wired in, is if the alternator ever does fail on you while in operation (and you catch it before the batteries are dead, or you have something to jump start it from) then the unit should have no issues continuing to operate with the battery charger plugged into the convenience outlet on front of the unit. If you have a hardwired inlet in the side of the gen, you might look at keeping a short extension cord with the unit just in case. (it's not likely that the alternator will fail, but the more prepared for it you are, the less likely for it to go wrong in my experience)
Triton
82
Houston, Texas
That's what I thought, people say they find the Pulse tech 24 volt solar powered for great prices but I never see them. I guess you gotta have good timing!
