Which of these three generators do you like the best comparison
Chainbreaker
2,079
Oregon
...There is an inconsistency though, if I am reading the Kubota Spec Sheet on the V3300 engine correctly. On the spec sheet Coug supplied it states: "Stable, predictable power. A unique fly-ball governor system stabilizes and regulates energy output for safe, predictable performance."
However, Abraham's spec's state: "Electronic Governor Mfg. by Precision Governors".
Perhaps Cummins somehow went with an electronic governor, or is that a typo?
Never mind, I see that on this generator it has the "Power Command 1.1" installed as an option. Also, if you were to ever fry the governor control board it is showing up on eBay as a $1,800 board for replacement.
Philratcliffe
9
Florida
I would probably go with the one that you can get parts the easiest for
Sent from my iPad using Tapatalk
This is colombia so very few business have many parts in stock so I’m good with Deere I can buy on line and have in two weeks tome and with all my 005s for back up I will always be able to provide power for the hotel
Philratcliffe
9
Florida
Both Kohler and Cummins have worldwide parts distribution, as do John Deere and Kubota, so likely a toss up either way.
Nearby there is a dealer/distributor that covers both Kohler and Cummins generators that claim to have trained and certified techs. This is for marine application, but there isn't going to be much difference between marine use and prime power, so they should be good for both parts and service if they make house calls.
Might give them a call first, see if they do send techs out and if they will do on site repairs, or if you'd have to take it in to them for repair.
https://www.noonsite.com/business/todomar-albornoz/
I know todomar we are buying a Pair of 300 mercs from them the end of Jan. They are one of the better dealers in Cartagena. Thanks so much for the info!
Philratcliffe
9
Florida
I would call Abraham Generator Sales first thing Monday morning and ask them the mfg's projected fuel burn rates for the gensets you are interested in at various loads...1/4, 1/2, 3/4, & 100%. That should get you in the ballpark of what to expect on fuel consumption. I can certainly understand that fuel consumption on an island is of paramount importance. I think the suggestion of trying to use solar for some of your needs is a long term goal to consider.
My experiences with turbo's on gas engines in cars is that they tend increase fuel burn. But that may be due to lead footing it in turbo'd cars. One of my cars is a bi-turbo V6 2.7L S4 Audi and no matter how conservative I try to drive, its gas mileage is not great. On the other hand, I have a 5.9L Turbo Cummins Ram HD truck and it does OK fuel wise especially when loaded & towing considering the weight factor weight. But that's apples & oranges comparing gas to diesel turbo's. To me if the engine is smaller (less pistons & displacement) and boosted via turbo each cylinder is doing more work as compared to a normally aspirated engine with more cylinders. But there is drag and rotating mass to take into consideration. The fuel burn rate projections supplied by mfg's should sort this out though.
Now regarding complexity and failure points... a turbo'd engine typically has more complexity/parts to fail vs a normally aspirated engine. Turbo bearings failures, oil seals failing allowing oil into intake air, coking of oil if right oil is not used & shutdown too hot are some of the potential issues that could be encountered in a turbo'd engine. If a turbo'd engine is not run with enough load it does not get hot enough you run the risk of wet stacking.
As far as the 25 kw normally aspirated Kubota, if it was broken in right and you use a good quality synthetic oil (Rotella T6 full synthetic, etc.) it should run a very very long time. The Japanese do a really good job of engineering and putting their engines together right.
Anyway, these are just my opinions for what its worth...I'm not a diesel mechanic or engine builder and don't have any experience using any of the generators you are considering.
The fuel buen in the Deere will save me a ton of money. Over time. Are turbo engines more prone to wet stacking? The 35 kw kohler only has 80 hours or so more on it than the kubota but is a grand less which pass for my first engine rebuild.
The oil selection here is awful. I can’t find rótella in this part of the country and no one here used synthetic oil due to price. I got it in medellin for my súper moto but here on the coast the best oil I can find for a reasonable price is cheveron 20/50. With oil changes every 500 hours that’s 16.5 oil changes of 3 gallons. The price diff on the oil over three or four year would pay for a rebuild. It it’s more about availability. It’s just nowhere to be found near me!
Philratcliffe
9
Florida
You might see about one of the military seabox units. They sold a good many off awhile back. Big diesel/electric freezer
Thanks for the info but I have all my fridges and freezers I will add a fridge for my beach bar and probably another large fridge for my restaurant and am making a cold room for storing fruits and veggies in a small 9x9 insulated room with a window ac unit that runs 24/7
Philratcliffe
9
Florida
Dayum that’s a lot. I think most tier 4 units have an electronic gov. I decided to purchase the kohler with the Deere 3cyl turbo for fuel consumption reasons. But thanks for all the info
Chainbreaker
2,079
Oregon
...Are turbo engines more prone to wet stacking?
All diesel engines are prone to wet stacking over time if not run with enough load. However, since a turbo-diesel has the turbine down stream of the exhaust, the exhaust side of turbine blades are subject to the unburned fuel slobber coating them and making them less effective. So its especially important on a turbo-diesel to routinely run in the 50 - 75% load range to prevent that from occurring. That's why on water cooled diesels you see thermal insulation jackets installed on diesel exhaust manifolds in order to retain heat.
Philratcliffe
9
Florida
Thanks so much for that explanation. Let me ask you a Q. Since the kohler I plan to by is a 30kw standbuy gen it’s actually only a 27kw continuos power correct so should I figure 50% load @ 1/2 of 27kw?
I think I will be @ 21-25kw load in the day time and will run my 005 at night at about 34kw
Chainbreaker
2,079
Oregon
Yes, if you can maintain a fairly continuous load in the 50% range of continuous power rating, since that is how you are running during day, I would think it should do fine. I've read that the low end threshold is 30% & ideal is 70%. So 50% should do no harm, however you may want to load it up to 100% load every now & then (perhaps monthly) for a couple hours to ensure any deposits get burned off.
If you have an IR Temp gun you can take readings after genset has thermally stabilized at various loads & locations...exhaust manifold, hot side of turbo, individual cylinder heads, etc. Ideally you can then establish & record a set of reference baseline readings under various loads. Then if you suspect something is amiss down the road it would be good to have those readings on hand to help troubleshoot problems...fouled injectors, low cylinder compression, valve timing, etc. The more information you accumulate now, the better.
BTW, I always run synthetic oil on any engine that has a turbo on it. As much as you run your fleet of gensets you should look into bulk purchase of 55 gallon drums of a HD synthetic diesel oil if you can find a way to have it shipped in.
HERE is a good article on wet stacking.
Philratcliffe
9
Florida
I will source 55gallon drums of synthetic oil, to be honest I should be doing that with my dino oil lol
I have a temp gun and that is a great idea to map the temp readings to help diagnose poor running issues in the future.
I just ordered a ir tachometer for my 002s so I can adjust them to 1800 rpms on the nose. Two of mine have iffy hz guages. Those lil 002s are **** near indestructible on the engine side.
Do you think I should wrap the exhaust manifold on the 30kw kohler to help it not wet stack at 50% loads and don’t turbos like the air pushing them as hot as possible?
Will running it at 99 percent continuously lead to an early demise? I’m building new rooms as fast as I can but most only add 90 watt draw to my electrical grid. I will run my larger 005s at night. At night I energize the air conditioners in my rooms that have them.
going forward if I have to I may run one of my 002s at night as well as the 005. Once we are finished construction and i know my fully energy loads I will buy another large modern tier 4 machine for night time and keep my 005s as back up to it.
Thanks so much for taking the time to help and advise me on this stuff I really appreciate it!
Chainbreaker
2,079
Oregon
If the engineers did their job & its OEM spec'd without exhaust wrap/blanket you should not have to in your climate. If you were running in an arctic climate it would be a different matter. If you don't see any evidence of wet stacking you should run it the way it is.
Don't know the engine so not sure? If your running it within design spec's it should be OK, but anytime something is run near redline continuously it increases stress & wear over time. However, lugging (low loading) a diesel engine continuously is bad if not worse. If running near 100% continuous load, proper maintenance along with using high quality oil & filter are key to a longer life
