Which oil do you use?
baja_power
Marysville Ohio
In my superduty and Land Rover i use Rotella, Rotella T synthetic in my vette. But in the deuce i usually just use cheap heavy truck oil. What do you use in your deuce and what weight? do you switch to a different weight in the winter months?
1,128
Rotella 15W-40 year 'round
rosco
Delta Junction, Alaska
RE: Re: RE: Which oil do you use?
Delo, 15-40, year round. If its cold, put enough heat on it till the oil will drip off the dip stick. I run it in everything. Deuce, John Deere tractors, Transport truck, Lexus, Toyota.
Lee in ALaska
wsucougarx
65
Washington State
Rotella T 15/40 in my Dodge Cummins for the past 8 years. Plan to do the same w/the deuce I just picked up and brought home today
Chow717
Mercersburg, PA
Re: RE: Re: RE: Which oil do you use?
Same as above but have only had my cummins for 6 years and will be picking up my duece next week!
CGarbee
552
Raleigh, NC
RE: Re: RE: Re: RE: Which oil do you use?
Used to run Castrol Agri 15w-40 but then they went up in price from being a buck less a gallon than Rotella to being a dollar more. I'm running Rotella now...
I use a lot of Warren products elsewhere and have studied the specs on thier 15w40 enough to know that they list the same ones that are on the Castrol, Shell, and Mobile products so I am very tempted to make the switch as the $$ savings would be large.
1,807
I've been running Coastal 15W40 which might be packaged by Warrren. I can find no difference other than the $3.00 a gallon savings.
CGarbee
552
Raleigh, NC
Re: RE: Re: RE: Re: RE: Which oil do you use?
Coastal is Warren... and you have nailed the cost bit that I alluded to... :)
