Which oil do you use?
oifvet
9
(near) Xenia, Ohio
Jake0147 said:
FMJ said:
I've been told that mixing Synthetic and "Regular" oil is a no-no, or is this an old wives tale?
Old wives tale. If you'd like, you can buy it pre-blended right off the shelf.
I just started using the synthetic blend in my non-MV, daily driver. I like the way it keeps a cleaner appearance at the oil change. I've heard good things about the "blend." It lasts longer amd leaks less.
I'n all about Rotella 15W-40 in the deuce with 20% Lucas Oil Stabilizer added.
I'm curious now after reading this thread, whether the Coastal or Delo is maybe a better product.
Need to keep studying.
Lex_Ordo
Long Island, NY
I'm just getting started and was told that a once a year full filter and oil change will keep everything in fine working order.
I also picked up, at the advise of a Club memeber, the Oil filter spin on adapter kit from JA Tonka to reduce the wear that is associated with the cartridge filters and lack of oil pressure on a cold start.
In a month or two I plan on picking up the new adapter kits offered for Spin on fuel filters too.
