which tire you would prefer
frauhansen
598
switzerland
Follow up question. Simply because the availabilities are currently rather poor
How big can the tire be maximum on a stock 1123? 38.5? 39?
Coug
4,759
Olympia/WA
IROK makes a 39.5" tire that fits a stock HMMWV as long as the springs aren't sagging.
As far as I know that's the biggest. Only caveat is with that tire size you can no longer run tire chains.
(the military tire chains add about 1" to each side of the tire, so on a 37" tire that makes it about 39", along with adding 1/2-3/4" to the inside/outside walls)
Hummer Guy
823
United States Louisiana
This what I'm thinking about doing later when I get my humvee over here but I will no doubt eventually give it a 2 inch body lift and 2 inch lift on the springs too
TOBASH
3,935
Brooklyn, NY
Can’t you add links to the stock chains to make them fit? Or are you referring to the overall tire height and width?
Coug
4,759
Olympia/WA
I meant overall size. With a rubber tire if something makes contact, you get a little rubber friction. If a tire chain makes contact, you can have some serious damage.
