Blood_of_Tyrants
- 10
- 38
- Lebanon, TN
DOH!i didnt think about stoping at a gas station to air up the tires until i was back at the dunes.
I don't like the new handbrake. When the brake is set and and I swing my legs out of the cab, the end of the handbrake pokes me in my left upper leg.I think the deuces handbrake, new version, is also a PITA.
This is how I do it as well, MUCH less frustrating, and I retain DNA that normally would be deposited on sharp edges. . .FWIW I pull the bracket off the block, attach said alternator then install both as a unit. Works for me! Your mileage may vary!
I recommended the 5/8 half moon wrench because it is easier to get that kind of wrench in behind the shrouded part of the alt bracket to hold the bolt head from spinning. From the other side, you use a normal, or ratcheting wrench.belts always tend to break at the worst possable time. i had my alt belts snap on the freeway on the way to a rally, thank god Hammer was running behind, he saved my ass, but in watching him help me change my belts(well he did most of the work, and i still owe him 5 bucks next time i see him) , ill never forget how to do it. then my aircompressor belt snaps in the middle of the sanddunes. had to drive my landcruiser with about 8psi in the tires, 12 miles on the highway to a library so i could look up the part number for the napa belt, then another 6-7 miles to napa to get it, then back to the dunes. i didnt think about stoping at a gas station to air up the tires until i was back at the dunes.
back on topic - it didnt take us very long at all once we got the right belts to put them on, it just took experimenting with about 10 or so belts until we came up with ones that would work. but i dont remember the alt giving us any trouble at all when it came to loosening or tightening it.
I agree with Cranetruck, and from No. 2 Diesel's help with my duece, I have found that I don't want to work on any other vehicle now except a Duece.The more you work on them the easier it gets, goes for generator bracket, belts, fuel and oil filters, brake fluid, injectors, hydraulic head, you name it...
