Who has best deal on axle rebuild kits? Bearings, seals, boots etc etc...
ScubaCat
Olean NY
Going to go ground up and do a COMPLETE rebuild of axles as a preventative nature. Who's got the best deal on parts? Dont want cheap chinese/off-brand parts.
What's the timken #s for bearings?
Thx.
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
Redbarn customs has a bearing kit
LARGE TAPPERED PINION BEARINGS W/ RACEs
1 SMALL LOWER FLAT BEARING
1 PINION SHIM PACK
1 LARGE & 1 SMALL PINION GASKET
2 PINION SEALS
For $600
I know the pinion seals are around $40 each from Napa.
I can almost buy two good used 5 ton axles for that $600.
Maybe cheaper and easier to get a set of old bearings and take it to a local bearing shop and have them find you the bearings. Check Oshkosh or another vendor for the NSNs maybe and then transfer it to the basic part numbers. Maybe cheaper. I do that for the 5 ton hub bearings and they are generally $15 or more cheaper than Napa or Truckpro.
