Who other than delks sells used parts for an mep 005?
Philratcliffe
9
Florida
Hi guyfang, I just bought another non running 005 and the seller is removing and shipping me all the electrical boxes, transformers, front panel gauges and switches, wiring harnesses, Injection pump, alt, starter, muffler for spares.
I also want to repair my exciter box so I have a spare one of these also.
Is it usually the voltage I that goes bad in the exciter box? I found a new in the box voltage regulator.
I would eventually like to purchase the test equipment needed to accurately diagnose any future problems but will buy them as I can over time on eBay.
I’m just trying to get my forth 005 running ASAP for back up to my other 005s as I’m switching over to the 005s today and putting my 002s out to pasture. One of my 005s will be dedicated to my rowpu. So I want a main and two spares to power my hotel. I also just bought a parallel cable for future use as my electrical demand grows.
Thanks so much for sharing your vast knowledge with me!
Guyfang
27,160
Burgkunstadt, Germany
Is it usually the voltage I that goes bad in the exciter box? I found a new in the box voltage regulator. (Did you check the part number against the part number in the TM? There are 400 hertz volt regulators for sale, that will NOT work with your set!!)
I’m just trying to get my forth 005 running ASAP for back up to my other 005s as I’m switching over to the 005s today and putting my 002s out to pasture. One of my 005s will be dedicated to my rowpu. So I want a main and two spares to power my hotel. I also just bought a parallel cable for future use as my electrical demand grows. (Read the book on how to hook this up and run it.)
Thanks so much for sharing your vast knowledge with me!.
Philratcliffe
9
Florida
In the parts Tm number 76 is nsn 6110-00-363-3973 or 3974. How do I tell which is the 50/60 hz version. By the usable on code? Where is the key as to which code is which version of the generator? Thanks so much for pointing that out!!!!
Is there a separate Tm book for parallel operation or a section in the regular Tm? Thanks.
Philratcliffe
9
Florida
Hey thanks for the tip on the voltage regulator. The one I found was for the 400hz 005. Still looking for a spare. If I can’t find one I have a friend going to the states in Jan that can take my exciter box to the states to get repaired
What does UOC stand for. Thanks so much for all your help!
Guyfang
27,160
UOC= Usable On Code. If you look at the cover of the TM, it covers 3 different gen sets. They are all very close to being the same, but still have deferances. So you need a way to tell what parts are different, for what model.
