Why shouldnt the 900 series be put into Reverse in Low?
350TacoZilla
Hancock MD
I am also a newbie but I can see why you cant use reverse in the truck in low after driving it for all of 10 mins, reverse is so low in truck and multiplies the torque of engine through the torque converter that in reverse low you literally spread the transfer case apart. I think it probably has to do with the gear design also, they are made to run forwards mainly and strength and wear are given priority going forwards since trucks will spend 90% going forwards and 10% in reverse.
also yeah you should try to search before starting new thread but we have all done it, no need to be a jerk about it ever single time it happens. Probably spend less time actually explaining the answer then telling them off, but for some I guess the chance to lord over others is to easy to ignore.
