ATC
- 0
- 16
- Roanoke, VA
Monster trucks use custom built ZF axles. Unless you were talking about rock crawlers and mud boggers. 'Crawlers use them for their strength. Mudders use them because they are cheap. A built D70/D80 combo would handle all the HP you could throw at them. They'll be lighter (not by much), disc brakes, and you can get parts for them anywhere, and you could gear them however you want. But that costs lots of money (about $2k each). 6.72 gears are not good for mud.So what sort of axle shafts do the monster truck guys use in the 2.5ton axles?
Not that I'm suggesting using those axles or anything...just some information to pass around.
Mud requires higher gearing than that and lots and lots of HP. Two of which you do not have. It takes A LOT of HP to turn 4 large tires in the mud...much less 6 or 10 tires with over 13,000lbs on them. You're talking quadruple-digit HP figures so spin them fast enough to keep cleaned out. My '78 Bronco has a 466ci big block in it that makes around 425-450HP, and it's adequate at cleaning out my 38" TSL's through an automatic (and 3.50 gears as of now...I really need 4.88's)Plus it would be great if the unit could hand 660ft-lbs of torque running through Fuller transmission with a first gear of 7.05 to 1 coupled to the 2.16 of the Oshkosh 55000 transfer case you have mud eating monster.
I understand that you are not building this to be a mudbogger, but when you do get in the soft stuff and your truck starts to sink...you'd better have the power to clean them tires out quick.
That's exactly what I was thinkingFYI, not the sprag T-136-21 TC, but YES the T-136-27 airshift TC gives you true 100% positive locked equal speed forward/backward 6x6 operation when front axle is engaged! Nothing less compared to a TC from a Graz or the Ural or the M880's NP203 when their internal diff. is locked.
I'm confused on this oneI'm sure the t-case does not lock up. Why else would mud boggers use the case? They never drive in the mud so they don't need traction like I do in my MV.
Either way, I really wish you the best of luck with this project, and I will be following it closely. A 5.9L or DT466 powered Deuce is something I've dreamed about doing for a long time. I might buy a parts truck and do the conversion in the near future
