wieght of dump unit
Robo McDuff
In memorial Ron - 73M819
1,565
Czech Republic
Does anybody know how much the dump unit weighs? I am talking about dump bed with sub-frame and hydraulics all together.
The M51A2 weighs in at 21,986 lbs, the M52A2 at 18,560
The M52A2 fifth wheel assembly and some other hardware probably weigh in at about 550 to 600 Lbs. So I assume the dump unit weighs about 4,000 lbs or 1,800 kg (weight M51A2 minus weight M52A2, add the 600 lbs of the fifth wheel to the difference).
Does this sounds ok or does anybody has hard data from the TM or other sources?
mckeeranger
Eastern Kentucky
That's probably a pretty good guess.
I can't remember what TM it was, but I remember reading the weight of an M809 series truck chassis is around 19,000# Wo/W. Our XM817 is just over 23,000# Wo/W. That would be the same 4,000 you are coming up with.
The dump apparatus on the M51A2 is essentially the same as the M817.
I'll see if I can find the TM with that information. It's on my external hard drive, somewhere. :-?
Robo McDuff
1,565
Czech Republic
Maybe it's in the operating instructions, like with the M39s, that's where I got the info.
I am designing and chosing material for the support legs for the dump unit, don't want to make them too light.
