gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 787
- 113
- Cincy Ohio
You said heat "could" release the refrigerant. Might one of those trash can fuel fired heaters be used to (heating the oil) release it? Would that release be toxic?
No, you are misinterpreting what is being said:so it should run, but there is a 4, or 0.4% chance it will eat your face.
good odds as long as you're not in missouri.
no chuck, i'm deliberately being a wisea$$. The points you have raised have been valid, I even understood the molecular diagrams you were using.No, you are misinterpreting what is being said:
-Chuck
We're getting off track here, but gas as a weapon was outlawed by the Geneva Convention (or was is the League of Nations) around 1920 specifically because of its devastating effects.WM,
You are correct about the WWI application.
The gases destroyed "the enemy's capability AND WILL to wage war", and therefore, by requiring large numbers of caretakers for the incapacitated.... created a HUGE diversion of manpower.
A very effective Weapon of War.
You are correct, and thank you for pointing out the detour that this thread has taken.We're getting off track here, but gas as a weapon was outlawed by the Geneva Convention (or was is the League of Nations) around 1920 specifically because of its devastating effects.
