will my mep 003a run with the fuse pulled 24 vdc
justacitizen
40
oklahoma
my 24 VDC regulator is overcharging the batteries. can i run the generator with the fuse pulled? will it discharge my batteries with the fuse pulled?
dstang97
30
Clover, SC
They say not to run your generator with out batteries, so that would be the same thing. They sell updated regulators these days that are much better.
Triple Jim
277
North Carolina
Actually, removing the 24v charging regulator's fuse that's near the oil filter and fan housing will just disconnect it from the 24v battery. The battery will still remain connected to the generator's control system, so the only problem is that it will slowly discharge with the generator running. You could connect a 24v battery charger to the 120v generator output, and let it charge the battery, which is a legitimate inexpensive way to solve the problem. Of course you could replace the 24v regulator.
justacitizen
40
oklahoma
I actually had a new Lakeland VR setting on the shelf with the other spare parts. we are having an ice storm and the oem VR went south. i was considering running with the fuse pulled for a few hours,but we had a break in the weather so i installed the new regulator Jim built and now all is well.
98G
Former SSG
3,995
That's hysterical
justacitizen
40
oklahoma
That's hysterical
actually that was exactly the info i was looking for. i knew i had repairs on the shelf but needed a few hours of generating. with the fuse pulled would allow me to wait for a more appropriate time to tear it down without damaging anything or overcharging the batteries.
98G
Former SSG
3,995
Yeah, I just found it really amusing. Like a Rube Goldberg device. A convoluted indirect way to charge the 24v system. Similar to me using my 5ton as an air compressor to run my plasma cutter.
No criticism implied.
justacitizen
40
oklahoma
i didn't take it as critic.. the only reason not to use a 5 ton as an air compressor is if there isn't anything bigger around
