rustystud
- 3,372
- 113
- Woodinville, Washington
Read post #47 again. Yes there is a fuel leak.
Turns out the single piece of crud I was just a small piece of black foam that broke off of the secondary filter and was floating around.I would keep running transmission fluid in the fuel for a while, maybe after some time it will help breakdown and clear whatever crud is causing issues.
No it will not. Only increase amount of fuel delivered. Not pressureQuestion:
Will turning up the fuel increase the fuel pressure while cranking?
.Any updates to a solution?
