Steamynachos
- 3
- 18
- Calgary Alberta
I might have a line on some 14.00r20 XZL's will these fit on a standard 5 ton split rim and can they be run with tubes in them?
Oops! Sorry, my brain skipped right over the 5 ton part! Probably because I just did the 14-20 the other day!area52 said:thats a deuce rim, I think stock 5 ton rims are a little wider than that.
What series 5ton? The M54 rims I had were the same width as the deuce: 7.5"area52 said:thats a deuce rim, I think stock 5 ton rims are a little wider than that.
gringeltaube said:What series 5ton? The M54 rims I had were the same width as the deuce: 7.5"area52 said:thats a deuce rim, I think stock 5 ton rims are a little wider than that.
OK maybe I am wrong then, thought I read on here somewhere that the 5 ton rim was wider.gringeltaube said:What series 5ton? The M54 rims I had were the same width as the deuce: 7.5"area52 said:thats a deuce rim, I think stock 5 ton rims are a little wider than that.
Not a std Deuce, not without some serious mods.yellobronc said:14x20's will fit 2-1/2 ton? I thought 11 x 20's were max? can we clarify for the 2-1/2 ton.
