Winch Bumber same as std bumper
KC4MNE
FtLauderdale, Florida
Is the winch and non winch front bumpers the same? With the difference being in the way the bumber is mounted.
I bought a "winch kit" but my non winch original bumper is in way better shape and I would like to reuse it
Manny
OD_Coyote
58
North Bend, WA
Manny - I am in the process of collecting the necessary parts to put a winch on my M35A2 and based on the info I found on this site; all you need to do is rotate the bumper 180 deg and you will be good to go.
FreightTrain
Banned
2,730
13
Gadsden,Al
yep,Just unbolt the bumper(with the triangular plates on bumper) from the frame,Remove the 2 handle thingys(What are these for?),slide the lower winch brackets into the frame and bolt it in,Now bolt the side plates to the winch(loosely) and sit the winch on the frame extenders previously installed and install the remaining bolts and the now upside down bumper and tighten everything as tight as possible.Don't forget the handle thingys since they bolt though the frame and lower extentions.
