WINCH CABLE CLEVIS END NEEDED
images54
gulf coast, florida
I used my deuce winch for the first time yesterday...... the cable broke right at the point it enters into the clevis. It appears that the cable rusted at this connection. So I grabbed a couple big pipe wrenches and tried to back off the nut that the cable feeds into, WRONG.... IT IS RUSTED SOO TIGHT i CAN'T GET IT APART. THE FUNNY THING IS, IT DOESNT LOOK RUSTED. AND BY THE WAY, THE CABLE LEFT ON THE WINCH IS IN EXCELLENT SHAPE WITH NO SIGNS OF RUST.
So I am in need of a replacement clevis. Anyone out there happen to have one I could buy?
Thanks,
Bob
doghead
4 Star General /Moderator
1,193
NY
A search for "winch cable end" gave me 55 results.
Floridianson
2,531
Interlachen Fl.
If you go to the Electroline sight put cursor on products that will drop down and you click on assembly kits. On the left side of the page should be Easy assembly down from that it should say play animation and below that it should say PDF format. If you don't see the PDF format put cursor on the play animation and then move cursor straight down one inch when the arrow changes to the hand stop and click there and that shows the real assembly instructions. Looks like you might need the assembly tool to?
jatonka
111
Ephratah, New York
winch clevis end
I soak them with CLP and wait a day. Sometimes they come apart, sometimes I have to apply heat, then they always come apart. Or just buy the new one. Either way you gotta put it all aback together, that's fun. JT out
emmado22
168
Mid Hudson Valley NY
I did mine without the assembly tools, I used a vice a 2 pieces of wood as jaws to hold and not damage the cable. Make sure you cut out the fiber core where the plug goes. I dont recall what the exact measurements are, but I do recall that I put the sleeve on the cable 3-4 inches farther down that what the instructions said, then put the plug in, and beat down on it until I was assembled to the correct dimentions as stated in the instructions.. Then, use a piece of bailing wire to "collect up" the strands that are all now "exploded out"... Crank down on the bailing wire, getting the strands to kinda come back to one point. Trim the excess strands to the length stated. Put the socket on, and cut the bailing wire, and screw the socket on. MAKE SURE YOU CAN SEE THE STRANDS THRU THE INSPECTION HOLE... IF YOU CANT, IT'S NOT ASSEMBLED PROPERLY.....Redo it until it is correct. Anything to do with the winch is not something you want to come flying apart under load...
