Winch cable lube
CARNAC
The Envelope Please.
724
College Station, TX
My wife yelled out the window at me today and wanted to know for Gods sake what I thought I was doing. I told her
"I just oil,oil, oiling my cable.
She got embarrassed about me doing it in public.
kenklausner
chicago
Try this link, we use this device with cleaning brushes on our winch lines. We pull underground cable through duct systems filled with mud and water and require frequent lubrication of the winch lines. Our winch lines are swagged three strand anti-rotation wire rope that does not have a core. While probably not in the market for a lubricator the various lubricants might be helpfull.
KK
http://www.viperwrl.com/assets/files/Viper Assembly & Operation Manual.pdf
broman78
great state of TEXAS
john deere Chain & Cable Lubricant sounds like it would work.
- 500ml
Applications: heavy-duty: Ideal for all types of exposed chains, drives, hoists, conveyors, wire rope, cable, sprockets, land and roller assemblies, garage and overhead door hinges.
Features:
- Excellent lubrication
- Penetrates rapidly
- Reduces friction and wear on cables
- Resists rust and corrosion
- Can be applied while machinery is running
AMX
Walland tn.
I have lubed my warn with chain lube twice in 20 years. It stays outside with a warn vinyl cover on it. Looks as good now as it did 20 years ago.
JamesSki
Appleton, WI
We use Lubriplate Chain and Cable Fluid (Penetrating Oil) I have not found a NSN though. There is one that CRC makes that is carried by Grainger though, called Chain and Wire Rope Lubricant. If you can find an NSN I'm looking. Thanks
73m819
329
gainesville, ga.
You DO NOT want to use USED motor oil on ANY CABLE, and for sure NOT ON FIBER CORE, the ACIDS WILL eat the fiber core, the acid WILL cause the steel core to rust, BOTH core conditions are NOT for good cable health.
frank8003
4,990
Ft. Lauderdale, Florida
Winch cable lube
Does anybody know what that protective stuff is that Uncle Sam uses on the winch cable, it works most excellent and I would like to get some to put on my winch cable.
This meets the specs
FLUID FILM WRO-EP Wire Rope Lubricant, Extreme Pressure
one may google it
see attachedView attachment winch cable lubrication 07062015.pdf
[h=1]MIL-PRF-18458C, PERFORMANCE SPECIFICATION: GREASE, WIRE ROPE - EXPOSED GEAR (05 JUL 2002) [SUPERSEDES MIL-G-18458B][/h]MIL-PRF-18458C, PERFORMANCE SPECIFICATION: GREASE, WIRE ROPE - EXPOSED GEAR (05 JUL 2002) [SUPERSEDES MIL-G-18458B]., This specification covers corrosion resistant externally applied grease for use on wire ropes and exposed gears of hoists, winches, cranes, shovels, dredges, and other similar equipment.
frank8003
4,990
what!?
Winch cable lube
one may google it
see attachedView attachment 568789
m16ty
228
Dickson,TN
The military recommends a Amsoil product, it think. There is a tag on the winch line of my new HMMWV winch that tells what they say to use. The winch is not with me at the moment. I'll report back what the tag says.
JasperM925A2
15
Washington
The Lubrication order calls for VV-L-751 which has been superceded by MIL-PRF-18458 C
I did do my diligence for researching wire rope maintenance. Proper lubrication/protection is a two step process:
1. Applying a penetration lubricant to lubricate all the way to the core
2. A sealant lubricant that provides a semi fluid or solid barrier to weather and moisture
Run out the cable to inspect, and wire brush off any corrosion or contaminants, blow out with compressed air.
Apply penetrating lubricant where the cable curves around the drum or a snatch block bue to the nature of the strands separating as the cable is pulled around a radius aids to penetration to the fabric core of the cable.
Apparently there are devices that attach around the radius of the cable and allow you to force lubricant in the cable under pressure, but I haven't researched any of those yet.
It does look like there are multiple aerosol type lubricants specifically for hoisting and pulling wire ropes that claim to perform both steps.
87cr250r
2,137
Rodeo, Ca
Late to the game here but Crater 2X is the go to wire rope lube. Crater is sold under the Texaco/Havoline names. Chevron sells it as NC 100.
The Navy Towing Manual has all of the information for wire rope lubrication.
S9086-UU-STM-010 also has information about lubrication.
There are pressure lubricators but the core is lubed during manufacture and the core lube is not renewable.
