- 1,200
- 457
- 83
- Spartanburg,SC
I have read on here that there is a difference between the A0/A1 and A2 winch controls. Can someone tell me or show me the difference? I bought one and don't know if mine is for an A2 which is what I need.
Did you shorten the pto shaft? And use the A1 controls?Also the pto shafts are different lengths between the A1 & A2's
I have removed a winch setup from an A1 & installed it on an A2.
No, I traded with someone here on the site.Did you shorten the pto shaft? And use the A1 controls?
Do you have any specifics on this? Sounds interesting.I have stock pto there now but plan to install an air shift pto & different winch control (smaller, cleaner setup) to give more room in the cab.
Thinking about it. I got a good deal on a winch, pto and valve. The controls I have are for an A1 though. If I can come up with all of the correct pieces, I will.I am just curious ??? are you going from your 924 to 925![]()
Andy,Thinking about it. I got a good deal on a winch, pto and valve. The controls I have are for an A1 though. If I can come up with all of the correct pieces, I will.
I think the winches are all the same but I have A1 controls instead of A2.Andy,
Your winch doesn't have a level winder. Doesn't that mean its for an A2? Did you get an A2 winch and A1 controls?
