No less than 2 snatch blocks.
Ok, I am good there. I have 2 of the correct deuce blocks that are NOS and an NOS block off the 5 ton (much bigger).
3-6 or 8 inch wide tree savers.
10' length seem reasonable? That's what Kenny recommended above. Or a short, medium and long assortment?
2 or more 50' sections of wire rope.
I assume the same 1/2" stuff that's on the deuce winch is sufficient? Since I am about to replace the winch cable on mine I can just get an extra 100'. How would you terminate it (see image "end terminations.jpg")?
You can bury a tire if there is nothing to attach your winch to.
Is a tire the better choice for an improvised anchor or just a "best bang for the buck" answer? I considered getting an anchor of some sort.
4x6 cribbing is good to have too. Length is up to you, but 6-10ft is recommended.
GTG here as well.
Sandbags with handles for the winch cable. I know folks say a blanket, but the handles can be attached with a clevis or beaner.
Good idea.
GTG here as well. I have a box of pins along with clips/cotter pins to mount them and a correct sized punch to remove the remnants.
Ok, let's talk clevis'. See image "shackle types.jpg". It seems the universal style is the screw pin anchor shackle. I've got a couple of big shackles in this style. How many are we talking? 2? 5? And can you recommend a manufacturer? I know the ebay/HF/Chinese stuff is trash and will explode easily, I wanna get the good stuff.
A guy I work with, that has experience with microwave antenna towers, suggested carrying a ground anchor that screws into the ground. Just spin it with a long pipe, breaker bar, etc.
Here's some I found with google:
Steel Earth Screw Ground Anchors | GME Supply | 800-940-6762 | GME Supply
You think those are sufficient? The largest one they have is only rated for 16K lbs.
Looking forward to other's opinions as well, thanks in advance.
C
