Window glass
Monty
Raymond Wisconsin
When I purchased this truck the pasangers side front window and drivers window were broke, can I use automotive safety glass or is there a special glass needed?
If I need glass were can I get it from?
Chad
acetomatoco
RE: Widow glass
the glass is just standard automotive material.. flat stuff.. Your local windshield guy will replace a door pane for about $40. The windshields should be safety glass reinforced AS1 and you can use lower quality for the side windows... you can also get it with a light tint if you want... have fun...Windshield World is the place to go here in VT, I am sure there is an equivalent type of shop there in WI
