Windshield dimensions??
joshs1ofakindxj
120
SW PA
WRONG WRONG WRONG!!!!
The link above will give you glass dimensions for an older deuce M135/M211.
They are not the same as the M35!!!
Now I have two pieces of new windshield glass for an older deuce that do me NO good.
Does anyone know M35 windshield dimensions?
I'm measuring 26-7/8" by 16-5/8" from the frame and that is leaving some wiggle room for rubber.
jerseyjeep2003
Gloucester City NJ
26 7/8 x 16 5/8 is correct, just go a little to the minus side on the 16 5/8 ( maybe 1/32 smaller), I had my new glass cut to those dimensions and it was real tight getting the top bar on. I had to use new frames, as I found the only thing holding the old ones together was the 12 coats of paint.
EWhytsell
Fort Mill, SC
^this very easy replacement, but I was able to get all the bolts/screws removed without issue.
willy
Martinez, CA 94553
They are for sale at Ebay
I found it cost as much for just the glass as it cost to buy new in box
with all new metal and rubber
He has 16000 off them
Willy
gringeltaube
Staff Member
2,282
Montevideo/Uruguay
Inner WS assy, ebay?
So far I haven't seen them for less than $149 + shp, ea. ???
G.
Willy
joshs1ofakindxj
120
SW PA
I got a piece of glass cut today locally to the 26-7/8 x 16-5/8 and it cost $28. Worked perfect. I sand blasted and painted my old frames and used a $11 caulking tube of oderless black silicone to seal it up. It was messy but it works!
Warthog
227
OKC, OK
Are you guys buying regular glass or DOT approved safety glass?
Flyingvan911
158
Kansas City, MO
I got DOT safety glass from my local Safelite for $25 a piece. It has a slight blue tint. They were out of the clear flat glass. They liked that I was putting it in a deuce. I had to put a bunch of POR 15 on my frames. They were badly rusted too.
