JAD561
- 0
- 6
- BETHPAGE NY
I have not seen this problem in any of the threads. My windshield wipers would only work on low speed with no washer pump. I replaced the whole wiper assembly with a rebuilt unit. I still have only the low speed. high speed still does not work, the washer pump does work, but here is the problem. Now the wipers will only work for about 5 minutes. The wiper blades then appear to drag or stutter. the wipers will stop working. i leave the switch on and tap the motor with a screw driver. the wipers will begin to work again. It seems that when i tap the motor, there is a large magnetic pull. I can't figure this one out. any help or advice would be appreciated.
