Winter storage tips?
HDN
5,299
Finger Lakes Region, NY
I get nervous about the underbody sprayers. Sure, fording is one thing, but pressurized jets applied to the underside? I'm nervous about that with my daily driver. Factor in freezing temperatures and you'd probably just freeze everything up. Yes?
fpchief
225
South Alabama
Thats what I was thinking, but it would be outside and made of 6 in steel pipe casing, because I don't have a "inside". In fact, I don't have a slab either, so when it rains, I use a 1 inch thick sheet of plywood treated with used diesel engine oil (really) and when it snows, I use cardboard. Its a good thing it doesn't get below -10F often.[/QUOTE
-10??? Don't think so...
Elijah95
Certified Rookie
1,240
1,211
Georgia
"I think you're missing out, not driving the truck in the snowy winter.
Just hose off the chassis after driving it."
You and your tactical military vehicle are not going to last forever.
Amen; If you really want to prevent rust, mix diesel and chainsaw bar oil in a pump up sprayer and mist the entire underside of the truck. The phosphoric acid in the oil with actively attack any existing rust/prevent new, and help salt and mud fall right off
montaillou
840
W.WA
Sounds like you just need to build a giant, heated/indoor drive-thru, sonic cleaner.
Problem solved!
davidb56
1,238
Bonners Ferry Idaho
No...not any different than driving through snow slush. the spray is warm too. Ive been using it for years and is real popular up here because of salt.
davidb56
1,238
Bonners Ferry Idaho
DSCF0133.jpg@ fpchief....Im originally from Stockton Ca. 100F+ temps often during the summer. It only takes a couple of winters to acclimate. Plus, with all those new fangled expensive gortex+ clothing out there, remember, its all junk. Wool is still King of the cold. Also cold winters acts like our own "border wall"!
Another Ahab
4,690
Alexandria, VA
First I ever heard of this formula:
- Where did you come across this "recipe", Elijah95?
And any magic ratio to the mix?
Another Ahab
4,690
Alexandria, VA
Where do you pick up something like that, davidb56?
Better question:
- HOW do you pick up something like that, 4'x8' sheet?!!!!
davidb56
1,238
Bonners Ferry Idaho
1 inch plywood is common here, but not in the big box stores, and it only weighs 60-80lbs. The trick is to brush on the used motor oil and get the edges a couple of coats, so the rain and snow cant penetrate it and make it real heavy.IMG_0051.jpg
HDN
5,299
I know car washes are able to reclaim water, but I'd hope it gets filtered or desalinated. Otherwise what's the point?
I'd be hesitant getting a car washed in the winter anyway. It's a good way to freeze your doors shut, nevermind anything underneath that it might freeze up. I think about how the Germans had to take a torch to their interleaved road wheels on their tracked equipment because they'd be frozen together! Same with some construction equipment I've seen.
davidb56
1,238
Bonners Ferry Idaho
I guess you have to experience Northern Idaho to see what actually works. 8 years ago when I first moved up here, my doors froze. Then someone told me to use spray silicon on the door gaskets, now they always open. There is a line every winter at the Bonners Ferry car wash that sprays the underside down. If it didn't work, eventually people would wise up. Im under my vehicle doing maintenance all seasons, and I know it helps. So...I'll do what I know best for me, and others can do whatever they want. Im not going to let winter "hibernate" the best vehicle made to do the job....M35A2C. period. But thanks for the concern...
HDN
5,299
I've learned a lot in this thread, that's for sure. I'm curious about the motor oil/diesel underside coating. Does that last for just one season? I can't imagine that being particularly healthy for the paint underneath, but I could be wrong.
mann650
Arvada, CO
Davidb56 - How are you tying down the blocks? I'm considering two IBC totes full of water for some weight so I can load and unload them myself. The cargo tie downs don't look like they could take the load but I may be wrong.
Another Ahab
4,690
Alexandria, VA
You got us interested plenty, Elijah95!
You got any more about all this?
HDN
5,299
I was mistaken. It's chainsaw bar oil, not motor oil. But still mixed with diesel.
