Wiper arms
IMA944T
OKLAHOMA CITY
My wiper arm are different. drivers side has long slim arm and pass has same length total arm but the slim metal parts is alot shorter. Anybody know of the difference in arms. Don't have digital camera or else I would post pic so nobody does the worthless without pic thing. I would buy a pair of the long slim arms from someone if they have a spare set.
Will marvel mystry oil lube the wiper motors??
coyotegray
10
Oklahoma City
I upgraded my wipers with the NAPA arms and blades and they work much better now.
Do you have plastic or metal motors..?
I use use lithium grease on them...
Andy...
IMA944T
OKLAHOMA CITY
Metal motors and what was the parts number for the arms? I got a set of blade and adapted them to the OEM arms but it was a pain drilling a hole for the clips to secure them.
Do you just pump a shot of grease into the air line?
coyotegray
10
Oklahoma City
If you search for "napa wiper arms" I’m sure it has been posted...
I used the grease on the shaft through the window and on the gear inside.
Just start taking it apart and you will see where it needs it.
Are they badly rusted/corroded..?
The metal ones are good. You can referb them more than the plastic ones...
If it needs lubrication inside, like the cups in the cylinder, I think I might use something like 3-in-1 oil..
Im not sure if there is a TM on these or not..
Andy.
