Wiper electric trouble
samurai
nice france
hello friends
i have a problem with my wiper blade switch
1)sometimes wiper blade working alone
2)yesterday i have a little smoke emission near the switch
i think there is a problem with the switch ,this one is use for turn signal , wiper blade and light control
at this time i have retired the fuse to prevent a damage
i need your help to find the good part
can you give me a link ?
i 'am not sure this one is good for my cucv m1009
Windshield Wiper and Windshield Washer Switch by ACDelco (part#D6354A) / Switches
CUCV Turn Signal Switch - CUCV Electric
thanks for your help
just one photo from my cucv
Warthog
229
OKC, OK
There are three parts that you are looking at.
The turn signal switch
BWD S3233 - Directional Signal Switch | O'Reilly Auto Parts
the wiper lever
Dorman Help! 49273 - TURN SIGNAL LEVER | O'Reilly Auto Parts
and the wiper switch
http://www.oreillyauto.com/site/c/detail/BWD0/S3465/02108.oap?year=1984&make=Chevrolet&model=K30%2BPickup%2B4WD&vi=1053021&ck=Search_wiper+switch_1053021_234&keyword=wiper+switch
The "lever" screws into the turn signal switch. TM 9-2320-289-20, Chapter 4-14 tells how to remove the lever.
The TM 9-2320-289-34 covers replacing the "directional signal" switch. Chapter 4-14
BUT how to replace the wiper switch is not covered....imagine that.....
samurai
nice france
big thanks for your message
i thinks the problem is the wipper switch
tell me if the link you give to me is ok for my vehicle
i will try to but it
if you know a shop who accept paypal it's better for me
bye
eric
Warthog
229
OKC, OK
The GM part number from the TM 9-2320-289-34P parts manual is:
7840274
Googling that number comes up with this link
7840274 - GM SWITCH
Looking it up on www.napaonline.com
NAPA AUTO PARTS
Part number ECH WS6040
Can't help you with the Paypal issue.
Is there a local part house that can cross-reference the part numbers?
GM 7840274
ECH WS6040
BWD S3465
Skinny
487
Portsmouth, NH
RockAuto.com accepts PayPal
I would also be checking for a short circuit or a jammed up wiper motor which would cause anything to smoke.
Nico
15
Germany, Hamburg
the wiper lever
got a Problem too,
when i Switch Off the wiper it freezes in that Position (mostly in the middle of the windshield)
would a New wiper Switch fix that Problem or is it a relay defect?
cpf240
Free in Northern Idaho
There is a "park switch" on the wiper motor assembly. Disconnect the two plugs on the pump portion of the assembly, pull off the cover and clean all the contacts. I found a broken wire inside mine, and after fixing that and cleaning the motors' ground strap, it works much better. Oh, and you may want to consider bypassing the noise filter capacitors.
Nico
15
Germany, Hamburg
hi cpf240!
i did as you said and it works just fine.
i sprayed all the contacts, motor, joints with wd-40 and the interval works again plus the wiper is twice that fast as before.
thank you again, for that helpfull advice.
regards
nico
