Wiper park location change
jpfever
-1
Hagerstown, MD
When my wipers are shut off, they park pointing to the driver's side of the vehicle. Is there a way to have the wipers park pointing to the passenger side, and still function correctly?
Pierreab
Hooksett, NH
Mine are the same ! I believe if you remove the drive arm from the motor and reinstall it 180 degrees out it should park them on the opposite side; I haven't been able to get to it on mine yet we're still getting snow up here !!! If you get to it before I do please repost your results, there have been quite a few guys who have posted the same annoying problem !!!
Sent from my SM-T800 using Tapatalk
suzukovich
141
Gibsonton Fl
Yes that should work. Did that with mine. You will have to pull the wiper motor in order to reset it. Also If you turn them off when the wipers are pointed towords the right the should stay where the are.
Action
1,552
East Tennessee
My wipers return to the same position no matter when i turn them off. But, if you cut power to the motor, that is a different result.
You guys could just move the steering wheel to the other side.
