Wiring an ATS to the MEP803a
kloppk
3,253
Pepperell, Massachusetts
Which 803 "Control Board" are you referring to?
I offer a Control Board that provides 2 wire Start/Stop capability to work with an ATS and other systems.
kloppk
3,253
Yes
All of the times for Pre-heat, Priming, Cranking, warm up and Cool down are all user settable. Different time delays can be set for WiFi start/stop and 2-wire start/stop.
The Pre-heat only occurs when the temperature is below 40F. The controller has a temperature sensor to determine if a Pre-heat is required.
In my signature area is a link to the listing in the classifieds. In the listing is a link with an extensive video that goes over a lot of it's features.
