rodymartin
- 0
- 0
- Marblemount, WA
OK I know that the batteries are wired in series but has anyone tried a series parallel switch out of a big truck in a cucv?
How do you propose to use such a switch? For what purpose?
In stock form the CUCV has both 12v and 24v circuits. It has 2 batteries that have separate alternators. It's a nearly perfect design.
Funny thing is that I know where an old B model is sitting right now. The series parallel in the trucks I worked on worked great.A series-parallel switch ? Really? Back in my B model Mack days most of them had a series parallel switch for the sfarter. These were also the beginning of my drinking problem in that they are also part of the charging system and the truck will not start if each pair of batteries (There were two pair of six volt batteries) was not equal to the other. Thank god for 12 volt starters and the elimination of that headache 1
Here comes the crazy "let's switch the truck over to 12V" guy! Roscommon 12V conversion. Google CUCV 12V conversion. Supposedly, this is what the Forest Service does to their trucks. There's two ways to do it, both of which you get instructions for. 1. You convert the truck to 12V, and keep GEN2 (which no longer needs to be an isolated ground alt, but can be) yank GEN1 and the wiring, and keep the two batteries (which are now in parallel) or 2. Keep both alts (neither of which needs to be an isolated ground, but can be), GEN2 charges the batteries (again, which are now in parallel) GEN1 charges a completely isolated 12V battery which can be used to power auxiliary equipment (for the forest service: pumps, winches, etc. for you: radios) Very minor rewiring and modification either way.If I can keep the 2nd Alternator and put a deep cycle charged by it only for the radios. I have at times had to work with search and rescue here in the mountains. The vehicle will be joined by a M1008 for hauling later.
