pbrstreetgang
- 0
- 16
- Kentucky
I am new to wiring and I am wanting to add some things to my CUCV but don't know where to start. I am planning on putting in a stereo with four speakers, two cigarette plug adapters with three ports each (one in the front, one in the back) and someday, a high powered LED strip across the front of the brush guard.
The first thing that I need wire up is the power adapters. Where do I start? Should I directly tap the fuse panel or use a fuse tap? Can I run one wire out to one power port, and then split off the same wire and run it on down the rear radio conduit into the back seat running both off of the same fuse?
Like I said, I need help starting.
