View attachment 764890 If I remember right, and I haven't laid hands on one of these sets since 2010, but I believe we wire tied these wires off about where the water temp switch is. The wire harness runs past the secondary fuel filter and water separator, then towards the temp switch.
View attachment 764891View attachment 764892
View attachment 764888 Mechanical speed switch. Is repairable. Don't fool with it, if it works. Make sure the lock down bolts are still tight, and safety wired. As you can see in the first picture i inserted, the speed switch adapter has a hold down clamp. I think yours is missing.
The two wires are not labeled I can't find anything it could be connected to. So I will probably put shrink wrap on the ends and tie the wires up somewhere.
Not sure what these halfway sticking out bolts are all about, but that doesn't look like it is supposed to be this way.
The fuel line in the last photo probably goes to the missing fuel filter assembly. I'll have to figure out how it was attached. and remedy this crapola.
