wiring is smoking on start up
84cucv1ton
New Jersey
bit of an update.. Cleaned all the grounds on the front of the truck and the flatbed. Clean all the wires on the terminal and all the grounds going to the motor. That braided little wire is very clean and still heating to the point it smokes.
Next idea is to go get a bigger table and make a new ground see if that does the trick. Thanks for the help guys
MarcusOReallyus
818
Virginia
The problem is that one of your ground wires isn't conducting all the current that it should, so that little one in the back is carrying too much.
You don't need a BIGGER cable, you need a GOOD cable. Bigger won't hurt, but make sure you are solving the right problem. You've got a bad ground. You need to find where that bad ground is and fix it.
MarcusOReallyus
818
Virginia
Get a meter on those ground cables. Disconnect and check the resistance (ohms). A visual inspection isn't good enough, and good connections on each end don't mean the cable in between is good.
84cucv1ton
New Jersey
finally done.. went over everything from front to back.. light seem to be brighter and its seems to crank over better.. shes running right now.. next to do is the fuel pump and the king pins.. thanks for they help guys
Warthog
240
OKC, OK
So what did you fix? Replace any wiring? Glad to hear you got it running.
84cucv1ton
New Jersey
redid all the ground.. forgot about the front one where you need to remove the grill and the one by the gas tank.. checked the ones i did put some electric grease down to stop corrosion.. then old welding cable from a intake bolt to the cab.. must have been pretty bad.. cranks over faster.. thanks agaon.. glad its running to :p
84cucv1ton
New Jersey
runs great. Still having a few wiring problems. Every time I had some good bumps in the road. A 20 amp fuse blows. I lose the running lights. Turn signals headlights break lights still work. Just no running lights.. Not too sure how to tackle this...
