juddspaintballs
- 1
- 18
- Berkeley Springs, WV
I have a working MEP-003a that I have not yet used to power anything larger than the two 120v outlets could handle on the control panel.
In light of this hurricane we're currently being hit with, I have no problem hooking up a safe lockout panel to run stuff with a 25' cord from my MEP-003a if we do lose power (still going strong so far), but I want a more permanent solution.
I also have a MEP-004a that I'm putting a motor in. The plan is to pour a pad and permanently mount it outside of my home. It has the ASK.
While I work on the 004, I want to be able to utilize the 003 in a permanent solution that I don't have to change out for running the 004.
I have 200 amp service in my house. I was considering buying a transfer switch panel because my current electrical panel is messy and it got some moisture in my basement at one point and the face panel is rusty. I've added and removed circuits since I moved into the house and since I'm considering selling the house in the next year or so, I would also like to clean it up to make it more appealing to a buying.
The best idea I have come up with so far is this:
Reliance Generator-Ready 200 Amp Panel — Dual Analog Wattmeters, For Generators up to 60 Amps/15,000 Watts | Transfer Switches| Northern Tool + Equipment
It is a 200 amp panel with a built in manual transfer switch that transfers over to a portion of the main panel that will run up to 60 amps of other accessories. The 003 is rated at 52 or 54 amps (don't remember) at 240v, and if I rewire my 004 to single phase, it should be capable of a bit over 60 amps at 240v. This would let me clean up the house wiring and have an integrated transfer switch with isolated generator circuits.
My only problem with that panel is that I want to wire in some circuits which would exceed that 60 amp rating. I have a 240v well pump, electric water heater, electric stove, electric dryer, heat pump with electric coils for defrost, etc. All electric house, basically. The well pump is non-negotiable -- it will be powered by the generator . I really want to be able to run my AC/heat pump, although I will never need to use the heat pump feature or defrost coils because I use an outdoor boiler for heat. I still want my AC in the summer though, and that would include my air handler. I can get away with not having an electric stove or dryer in operation because I have a propane grill and we can hang clothes in the basement if need be. I'm still on the fence about the water heater because I can heat my water via the outdoor wood boiler, but if it's summer, I would have to build a fire and start up the system just to heat my water. So I think that my well pump, AC and air handler, and POSSIBLY water heater would easily exceed the 60 amp portion of the panel. Conceivably, all of those could be running at once. I know the MEP's will handle the surge of all of those on at once, but that exceeds 60 amps.
So my other thought would be to just buy a new 200 amp house panel and wire in a manual transfer switch. Initially, I could wire in the MEP-003a with a male pigtail going to the switch and use a SO cable to the generator outside (trailer mounted). When I get the 004 ready to go, I could switch it over to a hardwired connection. This would allow me to run the entire house if I wanted (and the generator could handle it), but I wouldn't be restricted to the 60 amp side of the transfer panel.
I can probably do all of the work myself. I know I'll need the power company to kill power to my house when I do this kind of work. I'll probably still hire an electrician friend of mine to come over and help me do it (or more like I'll help him).
What are your thoughts? Use the 200/60 amp handy generator panel or use a normal 200 amp panel for the house and a manual transfer switch to switchover?
