witch would you rather have
big hoss
apex nc
Would you rather have a m35a2 with an air shift t case and no winch
or a sprag t case and a winch? Which would you rather have and why?
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
I'd get the one with the winch if they were the same price. You can swap to an air-shift for about $250.
Ridgerunner
Holland, Mi
If both trucks were the same condition (hours/miles, body condiction etc.)
I'd take the truck with sprag and winch. An Air shift t-case can be had for cheap ($100 -$300) and is readily available. They are easy to swap out also, which I'd do if I ended up with that truck.
A winch is more expensive to add to a Deuce ($800 -$1,300 for a complete setup, but I have seen them go for more) and a winch isn't as prevealent on the open market as an air shift t-case.
mcmullag
13
Colorado Springs, CO region
hard top, or singled out
one of the weirdest queries I have ever seen here. and ..... which, not witch.
For comparing deuces, the two items; a) sprag system for front axle drive engagement, as opposed to airshift engaged, and b) having a winch on the front of the vehicle or not, seem totally unrelated for most type of comparison scenarios.
I currently have a '87 M35a2c with airshift and winch, and not a wench. I have no need for the winch, sold my '71 M35a2 without winch ( but had airshift) in order to get one with winch, just because I thought winch trucks look cooler.
