Wobble while turning at highway speeds
Jinx
Buy me a Coke
202
Gainesville, FL
FWIW, I found out what was wrong with my deuce. I hadn't noticed it before, but the passenger side front tire tread pattern is terribly cupped. It looks like it was mounted previously on a truck that spun the tire in the opposite direction and had been badly worn, probably due to low air pressure for an extended period of time.
DanMartin
Hillsboro, Oregon (USA)
Make sure the tire didn't get that way because of your truck having an issue with alignment or bearings.
Regardless, it's about time for a new set of shoes. Probably good to check all around and see if any others need replacing as well.
A good upgrade is 11.00R20 Michelin XLs. Good offroad, a bit taller, and will fit on stock rims and allow you to still run duals on the rears. Sometimes a bit hard to find, but not expensive when you do find them (assuming surplus).
NDCC tires look cool but suck for traction.
Just a thought. Good luck with your truck.
