- 34,010
- 1,823
- 113
- GA Mountains
We.cut 55" out of a 5 ton dropside bed for JW4x4s 931. We did the bed install at the rally 2 or 3 years back. Came out darn near perfect.
No actually I have a 25 gallon tank mounted in behind drivers side step and custom air filter setup. Reason for that is I use truck PTO for the winch and bed and I also have an additional lines for rear mounted winch and knuckle crane that are not yet installed.Where did you move your hydro tank to? Or is it there and I can't see it?
Just the install was done at the rally. Not sure when the cutting and welding was done.Tell me more details if possible. You cut, welded and installed at the rally?
If you knew Carrie-Ann you'd know she always has been in controlYou should have gotten the big one ...Wife now has control...Great find have fun with it.
