- 18
- 12
- 3
- Bullhead city Arizona
so i picked up a m1151a1 slant back at govplanet and it seems complete after my initial inspection. i have changed the oil and all other fluids seem clean. the spedometer gauge panel with the gauges was missing but the tech who removed it left the wiring in good shape. still has the plugs and no wires mangled. i had figured that i would bleed the fuel by the purge line. but no fuel after cranking it . with a small amount of clean fuel sprayed into the intake it didnt seem to ever come alive. my question is with the gauge panel removed is there something keeping it from firing over? there was a decent amount of left over fuel in the tank but i had added 5 gallons of fresh fuel. i was tpld by a freind who owns 5 of these to open the fuel drain valve near the naster cylinder and crank a bit until fuel comes out then close the valve. but i havent seen any fuel yet. i would appriciate any advice. thanks
