Wondering what it takes to single out a rear axle
bigelk50
13
albany, Or
I have searched forums, with no luck, trying to figure out myself what it takes to single out a rear axle in order to bob a deuce. Any info is greatly appreciated. I am going to run singles and do not want it to look dumb.
1,806
The rear hubs need to be flipped and the studs reversed. Simple task requiring only hand tools. It's all a bolt together ordeal.
Alex400
Seattle/Ellensburg, WA
Re: RE: Wondering what it takes to single out a rear axle
What do you mean by flip the hubs? I have seen pictures or diagrams of it but I don't exactly understand the exact process.
Alex
BFR
Rocket Surgeon
2,331
North Georgia
remove ...
wheel,
axle,
spindle nut, tabbed washer, another nut, seal, outer bearing,
hub & drum assembly
unbolt the hub from the drum
drive the lugs out
drive them in from the other side
bolt the hub back to the drum
put it all back together.
Barrman
1,685
Giddings, Texas
RE: Re: RE: Wondering what it takes to single out a rear axl
Look at your front wheels. Notice how the rim is even with the end of the hub? Now, look at a rear hub. It sticks out way past the wheel. The front hub is flipped "out" and the rear hub is flipped "in." Just unbolt a rear hub and turn it around. As Kenny pointed out, the lugs need to be turned around as well.
Barrman
1,685
Giddings, Texas
Sorry about the waaay to late post. I opened the thread up an hour or so ago, dealt with stuff at work and came back to it without refreshing the page.
