Wont start when warm?
gungearz
northwestern indiana
I had a "nipped" gasket in a fuel system once. It would act as a check valve. It would close while there is no pressure with the pump off and the fuel was resting on it but would suck air in while the pump was running. The only indication that there was, was a small drop size wet spot on a gasket. I've never dealt or even heard of this problem before, until then... So now if I have starting or fuel issues, that's another thing I look for. Other then big wet spots.
KrispyKris
Kuerten, Germany
Wow..this is an old thread.
Hello from Germany. I have a customer with a 1984 dually with only 52K on the clock. Cold Start, no problem. Warm Start...no start. My brother visited us for the first time since I have been here (2005), and the customer begged us to come by his job-site (Landscaper) because the truck would not start at the end of the day. (or when Hot). NO fuel leaks, and it starts every time when cold. Just will not start when it is already warm. I will advise them about the Chinese water bath to see if that helps. I forgot that I now have a phone that is more intelligent than I am, otherwise I would have clicked off a few pictures. One thing I found was that the vacuum line on the thingamajig on the TPS? had a rip in it at the connection. This is the line that GM ran from the vacuum pump. I have had a lot of experience with the GM diesels. Those folks should be tarred and feathered, sent out of town on a pole to be slowly roasted.
Cheese and rice. Taking a gas engine and turning it into a diesel? I remember finding head bolts laying next to the rockers....
All the best.
cucvrus
10,505
Jonestown Pennsylvania
The injection pump has checked out and needs replaced. And the 6.2 diesel is not a converted gasoline engine. The Goodwrench 5.7 diesel was a converted 350 Oldsmobile gasoline engine. And in the end after replacing and redesigning the engine they done it right. But by then the damage was done. It needs a rebuilt injection pump to correct the warm no start condition. Good Luck.
1,191
You may only need the top cover with the shut-off solenoid.
